Hi, looking to build a gaming-based system. Feedback are appreciated.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
A: In order of priority: gaming, video streaming, programming, work
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
A: $900
3. What country YOU will be buying YOUR parts from.
A: USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
A: Intel-Fanboy
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
A: mouse, keyboard, 22" monitor, OS (win7), stereo speakers
6. IF YOU have searched and/or read similar threads.
A: Reference below: http://www.tomshardware.com/reviews/best-gaming-cpu-intel-core-i7-amd-phenom-ii,2926-3.html, http://www.tomshardware.com/reviews/p67-motherboard-roundup-lga-1155-sandy-bridge,2837-30.html
7. IF YOU plan on overclocking or run the system at default speeds.
A: Not interested in OC
8. What resolution YOU plan on gaming with.
A: 1920*1080
9. WHEN do you plan to build it?
A: ~ in 2 weeks
Misc: I prefer a cool (i.e. temperature), quiet and stable system that can play games at decent settings. However, I don't play FPS so I think I don't need top-of-the-line hardware. Listed below are my current configuration, and my justifcation for buying them, if any.
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB
L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
$214.99
http://www.newegg.com/Product/Produc...-072-_-Product
Justification: Since I don't want OC, according to this post (http://www.tomshardware.com/reviews/best-gaming-cpu-intel-core-i7-amd-phenom-ii,2926-3.html), I know that I should pick up I5-2400 for $189.99. But since it's only like $25 difference, I decided to go with this anyways.
ASRock P67 EXTREME4 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
$159.99
http://www.newegg.com/Product/Produc...82E16813157229
Justification: P67 seems like a very good MB for I5-2500K. And this seems like a nice, cool card based on this post (http://www.tomshardware.com/reviews/p67-motherboard-roundup-lga-1155-sandy-bridge,2837-30.html).
Asus EAH6850 DC/2DIS/1GD5/V2 Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
$159.99 ($139.99 after rebate)
http://www.newegg.com/Product/Produc...82E16814121419
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
$20.99
http://www.newegg.com/Product/Produc...82E16827135204
Corsair Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
$84.99 ($69.99 after rebate)
http://www.newegg.com/Product/Produc...82E16817139005
Justification: I know I don't need 650W, but I prefer to be a little over for potential future upgrades.
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3
10666) Desktop Memory Model F3-10666CL9D-8GBRL
$84.99
http://www.newegg.com/Product/Produc...82E16820231311
Samsung Desktop Class Spinpoint F3 1 TB SATA 3.0 Gb-s 32 MB Cache 3.5-Inch Internal Bare-OEM Drives, HD103SJ
$59.99
http://www.amazon.com/Samsung-Spinpo...4694369&sr=8-2
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
$99.99
http://www.newegg.com/Product/Produc...82E16811129021
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact"
Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
$29.99
http://www.amazon.com/Cooler-Master-...4719457&sr=8-1
Justification: To cool the CPU better than the stock heatsink & fan to achieve a higher level of quietness.
Thanks.
A: $900
A: USA
A: Intel-Fanboy
A: 1920*1080
A: ~ in 2 weeks
$214.99
$159.99
$20.99
$84.99
$59.99
$99.99
$29.99
Thanks.
