Please Help With Soggy Laptop
Caveman
2,539
34
I just got one of these ~2 months ago:
http://www.newegg.com/Product/Produc...82E16834115681
It's been a great machine thusfar...
Then a few hours ago our 2 year old dumped about 8 oz of water on the keyboard.
The machine locked up and the power switch did not work so the battery was pulled to cut power.
It's drying out now... Luckily, the water was bottled spring water (like the kind at "work" that sits on a cooler). The laptop was dried as much as possible, and now it's sitting there on the sink drying out... Planning to rotate every 6-12 hrs to get water "out".
Any other ideas?
How long should it take to dry out?
Dec 10, 2005
29,192
14,580
If there are removable panels underneath, you can try taking those off. Maybe add a fan blowing over the laptop to increase airflow and speed evaporation.
I'd probably give it at least 24 hours to dry, but it couldn't hurt to let it dry for 2-3 days.
Decembermouse
141
Yeah, remove battery and power cord, which I'm sure you've already done.
I'd leave it for a few days, as long as you can stand to. It's important that the circuitry is completely dry before you turn it on again. My freshman year of college, a drunk guy thought my room was his and peed on my roommate's laptop. Fried it. If it'd been off and unplugged, and if the pee was pure water, I'd hazard a guess that once it had a chance to dry out it would have been fine, but... :p it was not, in this case. The sizzling noise and smell of burning urine woke me up! Not a good night!
(edit) I realized I just made it sound like this guy would have peed in his own room. He thought it was a combination of his room and the bathroom. Asked what the **** we were doing in his room, and that he was just trying to take a leak so could we get out of the bathroom...
taltamir
13,576
pee is never pure water. and neither is spring water.
Pure water is dangerous and can be deadly when drunk due to osmosis.
Water does not actually conduct electricity, the solutes in the water do; as the water naturally dries, it deposits said solutes on your electronics. Furthermore, water can cause corrosion of materials.
you want to disassemble the laptop ASAP. Wash the affected electronic parts with deionized or distilled water to remove the sediments from your bottled water, and then dry them quickly with a hair blower to prevent risk of corrosion.
although, if you get lucky, it can just work without anything more then letting it dry.
Raduque
13,140
138
This, but if it were me, I'd get a large enough plastic tub to hold it, toss it in there (open) and fill the thing up with isopropyl alcohol. It'll displace the water and minerals and evaporate cleanly.
It's worked well with me for phones that have been drowned.
Decembermouse
141
There's actually no hard evidence of this being deadly or dangerous, just people saying you won't get your essential minerals... but drinking water isn't a significant source of minerals. We get our minerals from food, because in food they are in compounds that make them bio-available to us, which isn't the case with water. Others say that since it has no minerals, it will damage your organs by leaching all the water-soluble minerals and compounds of them. I've even heard that one's stomach can implode and cause internal bleeding. I work at an infant formula and pharmaceutical nutrition plant in the chem lab, and we use DI, RO, and Milli-Q water for many things. We've looked into this and it turns out no, it's not dangerous. The concentration of minerals in even tap water, or distilled/filtered bottled water, which millions of people drink daily, is so very hypotonic compared to every single cell in your digestive system that would interact with this water, that if RO water would have these supposed negative effects on you, then tap water would be 90-something percent as damaging as RO water supposedly is. Your cells won't lose all their nutrients to RO/Distilled/DI water; it only makes it easier for cells to rid themselves of waste molecules and minerals. There's no research study I'm aware of indicating that this kind of water is dangerous, just speculation on the internets. We've tried to find this evidence, because one of the ladies in the lab was absolutely convinced that drinking RO water could kill you, but to no avail.
At the same time, I prefer tap water because it's FAR more convenient, I like the taste better (I've had plenty of pure water), and because pure water doesn't have Fluoride, which over the years is good for teeth. :D
But yeah, you're absolutely right, it's the solutes in water that make it conductive. Urine definitely is full of those... hence the increased density, the color, and smelllll :x
corkyg
Elite Member | Peripherals
27,370
240
If that happened here in Arizona, I would remove as many things as I could and then place it out on the patio in the sun for a few hours. It will dry out. :)
Caveman
2,539
34
Update... Let it dry out for 3 days and kept it near a heating vent. IT WORKS!
taltamir
13,576
What? no I didn't mean any of that, those all are just urban legends.
I meant you will get water intoxication quicker due to it having less solutes.
http://en.wikipedia.org/wiki/Water_intoxication
and it has nothing to do with "leeching minerals from cells", its water that will enter cells via osmosis, increasing the pressure of water in your brain.
its GREAT to use for making things, but when you do it is no longer DI water. Do you drink it straight?
1. Bottled water is not distilled water, or if it has been distilled, salts are added back in.
2. Your intestines are not at risk. It is simply a case of smaller amount needs to be consumed to become water-intoxicated.
It is, drink enough tap water and you will drop dead. most people don't do that unless they do a "Drinking contest" or heavily excercise and drink throughout the excercise without eating anything or otherwise replenishing their electrolytes, but it is far easier to get into the water intoxication state then it is to get water poisoned. And that is perfectly doable with tap water. It is just exasperated by drinking pure water.
So if you are indeed correct about the 90% figure, then if it takes a specific person (individual amounts vary) drinking a gallon of tap water with no food to die of water intoxication, then it will take that same person 0.9 gallons of DI water. Note that if said person is merely intoxicated, he could still die from having a car accident.
of course they wouldn't, the cell membrane prevents them from passing, it is water that will enter the cell. Eventually it could cause cells to lyse, but that will only occur in a laboratory, in a human body, you will die from increased pressure on the brain before any cells will actually lyse.
It is really quite simple, find out the amount of solutes in DI water, find out the amount of solutes in tap water, find out how much tap water it takes for a person to die of water poisoning and you can easily calculate how much DI water it will take.
It is however quite possible that the difference between the two is insignificant; I have not actually done the math, I am making an educated guess here.
BTW, the advertising point of energy drinks for athletes like gator is that you could drink buckets of them and not die from water poisoning. because death by water intoxication is a very real issue for athletes.
Decembermouse
141
Yeah, I heard about a guy a few years back who was hazed, I think at some Ivy League school, and they made him drink something like 4 gallons of water. Not sure if he finished that or not... kind of doubt it. Talk about your LD50. Jeeeeez.
Yeah, I'm not sure about the 90%; it depends on whether it's RO, DI, Milli-Q, or some other brand, and to a smaller extent, the hardness of the tap water that is being processed. But I think you're right about that ratio there, in terms of the effects of minerals.
You're absolutely right, assuming that it's the lack of solutes in water that causes the 4 gallons or whatever it is to kill someone. Major systems start to fail, and without them, it's not a pretty picture.
