I installed my Radeon into a Dell 8100 and soon after I noticed some funny things going on. The problem is I have this weird "bubbly" oscilations on my monitor.
They look kinda like what you get from EMI but I never had a problem with my old card in the same setup with the same monitor in the same room. I've been blaming my ps but I thought I should get more/better opinions before I set fire to the ps in a fit of rage.
It's a dell 8100 with a very old P4, 384Mb PC800 RDRAM, maxtor hdd, on a 423-pin Dell i850 mobo, the ps is a 250watt which *is* slightly below spec.
However since Dell continues to use identical ps in the new models (8200,8250,8300) and they are sold with Radeon 9700/9800 cards I thought I should be ok.
This fall I plan to use the card in a brand new system and I want to be sure I don't have a broken 9500 Pro.
I tried another monitor and it seems to have the same problems, so something in the case is likely at fault.
Could such a low-watt power supply (even with such a light load) be at fault? Are there any issues with old-school P4s on i850 motherboards I should be aware of?
Please any other suggestions would be greatly appreciated
Thanks.
Thanks.
