Please help with nForce problem
elwood03
I'm hoping for some help for someone who's been around here since the beginning but only comes up as a junior because I lost my old ID - frequent reader, infrequent poster.
I was upgrading my second computer from an old KT133 board to an ASUS nForce board. I've build at least 20 or so systems and I've never had this problem. I put it together, go to boot up, the fans, start spinning, but I never get a video signal and I get no error messages. If I remove the memory, I get the same thing - still no error beeps. I think I've tried everything but I'm not excited about having to RMA the board to NewEgg. I've always had good luck with ASUS but then again, the ECS SIS board on the system I'm typing is flawless.
Hope someone can help!
Check your CPU and make sure its seated properly and that the HS is making proper contact. Other than that, you probably got a dead board. Just RMA it.
Do you have a 3-pin header fan plugged into the plug marked "cpu fan"?
Asus has made their recent boards so that they won't boot without a fan.
