PLEASE HELP with my TEAC Burner
ruatechnut
38
I am having trouble with the TEAC/CD Creator I just installed. I am trying to make back up cds of my daughter's video/learning cds and I keep getting this message:
An exception OE occurred at 0028:C145F3AF in VxD CDRALVSD(01) + 00003515. This was called from 0028:C145BE90 in VxD CDRALVSD(01) + 00000000. It may be possible to continue normally.
I even got the same message when I went to make another copy of a back-up software cd that my brother-in-law made with an 8x burner. When closing out the above window, this time it caused this illegal operation:
CDCOPIER caused an invalid page fault in
module CREATOR.DLL at 017f:014b8b51.
Registers:
EAX=007723b0 CS=017f EIP=014b8b51 EFLGS=00010246
EBX=00000002 SS=0187 ESP=0064e36c EBP=0064e3bc
ECX=00000000 DS=0187 ESI=00775020 FS=12d7
EDX=00000000 ES=0187 EDI=00000000 GS=0000
Bytes at CS:EIP:
ff 51 3c 8b 4e 20 e8 81 0b 00 00 66 39 46 2c 0f
Stack dump:
007723b0 00000000 0064ec98 00000000 014c3f73 00016b04 bff71547 0064ec98 00775020 014c3ecf 0064e440 014b6a03 00000001 00000b40 000005f8 bff7b9ae
I have been able to make a copy of an audio cd & one of my daughter's cds but they would not burn higher than 4x. The cdrs that I am using are the K-Hypermedia from Office Max. DMA is enabled.
I am running a Gateway PI system w/98SE that has been outfitted with evergreen's overdrive processor AMD K2 333mhz, 64mb ram, mitsumi 32x cdrom, & a Western Digital Hard drive. I have the Teac slaved to the cdrom & slaved onto the hard drive is an Iomega Zip drive. I checked with Iomega regarding slaving from the hard drive & they said if it worked upon boot up that it would be ok.
Any help is GREATLY APPRECIATED!!!!!!!!!!!!!
4824guy
Make sure the HD is not defragged alot. Try running a defrag before making that disk if you haven't done so recently. Also try burning at a 2x speed to see if that is a problem.
