Please help with MS Access
bcmind
I have a Table:
Class Rep Sales Cost
AC 10 $5 $2
AC 39 $5 $2
AC 10 $6 $3
AC 39 $10 $3
QS 10 $2 $1
QS 39 $2 $1
QS 39 $2 $1
QS 10 $3 $2
I want this result:
Class Rep Total Sales Total Cost Profit Margin
AC 10 $11 $5 120%
AC 39 $15 $5 200%
QS 10 $5 $3 66.67%
QS 39 $4 $2 100%
Please teach me how to do this... TIA!!!
LeiZaK
3,749
4
In "SQL View" for a new query, enter the following:
SELECT [tablename].Class, [tablename].Rep, Sum([tablename]![Sales) AS [Total Sales], Sum([tablename]![Cost]) AS [Total Cost], Round((([Total Sales]-(IIf([Total Cost] Is Null,0,[Total Costl])))/[Total Sales]*100),2) AS [Profit Margin]
FROM [tablename]
GROUP BY [tablename].Class, [tablename].Rep;
I think that will do it...
Also make sure that in the "design view" your Sum and Round fields are set to "Expression" and the others are set to "Group By"
bcmind
LdiZak,
Thank you for your reply... and it works great... but now on the the next step...
I want this result:
10 $16 $8
39 $19 $7
Total Sales is coming from AC + QS (Total Sales)
Total Cost is coming from AC + QS (Total Cost)
TIA!!!!
LeiZaK
3,749
4
Originally posted by: bcmind
LdiZak,
I want this result:
10 $16 $8
39 $19 $7
TIA!!!!
Sure.
SELECT [tablename].Rep, Sum([tablename]![Sales) AS [Total Sales], Sum([tablename]![Cost]) AS [Total Cost]
FROM [tablename]
GROUP BY [tablename].Rep
bcmind
LdiZak,
I want this result:
10 $16 $8
39 $19 $7
TIA!!!!
Sure.
FROM [tablename]
You are the best!
bcmind
Originally posted by: beggerking
use Format( your calculation, "Percent")
to show percentages.
I'm sorry... i'm kinda new to this... can you explain it in more detail?
LeiZaK
3,749
4
LdiZak,
I want this result:
10 $16 $8
39 $19 $7
TIA!!!!
Sure.
FROM [tablename]
You are the best!
:D
LeiZaK
3,749
4
SELECT [tablename].Class, [tablename].Rep, Sum([tablename]![Sales) AS [Total Sales], Sum([tablename]![Cost]) AS [Total Cost], Format((([Total Sales]-(IIf([Total Cost] Is Null,0,[Total Costl])))/[Total Sales]*100),"0.00%") AS [Profit Margin]
FROM [tablename]
Look where I updated the Profit margin section... I think that's how it works.
beggerking
1,703
Great job!!
I think the only thing is.. you need to actually type out "Percent" .. its a function constant..
bcmind
OK.... problem with synthax....
SELECT PCSLS.Class, PCSLS.RepNum, Sum(PCSLS.[Sales Amount]) AS [SumOfSales Amount], Sum(PCSLS.[Cost Amount]) AS [SumOfCost Amount], PCSLS.Profit, Format((([SUMOFSALES AMOUNT]-(lf(([SUMOFCOST AMOUNT] is null, 0, [SUMOFCOST AMOUNT])))/[SUMOFSALES AMOUNT]^100, "0.00%") AS [PROFIT MARGIN]
please help!
LeiZaK
3,749
4
please help!
Try the word "Percent" in place of the "0.00%" as beggarking mentioned and see if that works...
bcmind
Format((([SUMOFSALES AMOUNT]-(lf(([SUMOFCOST AMOUNT] is null, 0, [SUMOFCOST AMOUNT])))/[SUMOFSALES AMOUNT]^100, "PERCENT") AS [PROFIT MARGIN]
no go :(
LeiZaK
3,749
4
no go :(
Can you do without the percent sign? :p
beggerking
1,703
no go :(
try delete ^100 out...
KLin
30,440
752
no go :(
Use formatpercent() instead of format().
FormatPercent([SUMOFSALES AMOUNT]-iif(IsNull([SUMOFCOST AMOUNT]), 0, [SUMOFCOST AMOUNT]/[SUMOFSALES AMOUNT])) AS [PROFIT MARGIN]
EDIT: it would be better not to include spaces in field names (ie, instead of [PROFIT MARGIN] you should use ProfitMargin, etc.)
LeiZaK
3,749
4
no go :(
I know that... and you know that, but don't go pushing your nomenclature around here. :p
bcmind
no go :(
Format((([SUMOFSALES AMOUNT]-(lf(([SUMOFCOST AMOUNT] is null, 0, [SUMOFCOST AMOUNT])))/[SUMOFSALES AMOUNT], "PERCENT") AS [PROFIT MARGIN]
no go :(
bcmind
no go :(
no go :(
bcmind
Originally posted by: 6000SUX
I'm surprised no one remarked on the lack of a primary key.
everything is on the same table... no other table is involved... do I still need a Primary Key?
bcmind
just to refresh everyone's mind... this works w/o calculating the "Percent"
I just need the Percent to work..
SELECT LauraAllClassAMT1.RepNum, Sum(LauraAllClassAMT1![SumOfSales Amount]) AS [TOTAL SALES Amount], Sum(LauraAllClassAMT1![SumOfCost Amount]) AS [TOTAL COST], Sum(LauraAllClassAMT1!Profit) AS PROFIT
FROM LauraAllClassAMT1
GROUP BY LauraAllClassAMT1.RepNum;
