Please help with FOP-32
rbownes
99
I just bought a FOP-32 for my CUSL2-C and Celeron 633. I dont know if it is a 32 or a 32-1 but it is silver color. The saleperson wasnt going to sell it to me because he said it was only for a Athlon TB or Duron. But he eventually did. Will this hsf work for me? He said if i crack my cpu then i couldnt return it. Will it fit? How is the best way to install it?
Thanks for any help.
Viperoni
11,084
The fop32 is black, and has a ridge that sticks out along the bottom.
Your fop32-1 should have no ridge at all.
I personally installed a fop32-1 on my celery 366/bp6, and although I was shaking a bit, it went fine.
Would I be worried if I were you? A bit.
blackhawk
2,690
I used the 32-1 on a 600 at 927 with a slotkit too and it worked great, just moved it over to the duron now. It has a little step to butt up against the socket, no different than the duron socket.
It'll work fine.
