Please Help with BSOD Win 2000 Related
cabmeister
15
Hi
Well it never took long for the following page fault to rear its head again,and thanks to your advise i was able to copy it all down as follows.
***STOP: 0x00000050 (0xE359B000,0x00000000,0xBFDAB842,0x00000001)
PAGE_FAULT_IN_NONPAGED_AREA
***Address BFDAB842 base at BFD5E000
Date Stamp 3a09dd93-TBirdHD.sys
I hope that this makes sence to somebody ,and could point me in the right direction to remedy the problem .
Thanks in advance for your time and trouble guys.
System Specs:
main board= biostar k7mia
cpu= amd 1900+
ram= 512 meg mushkin 22 , 2100 ddr cas2
HS/fan = dragon orb 3 7,000 rpm
nic= netgear
sound= philips acoustic edge
scsi controller = adaptec 29160 UW 160
hd 1 = 20 gig ibm scsi 160 10,000 rpm
hd 2 = 60 gig WD IDE ata100 7,200 rpm
std floppy
twin fan HD cooler for the scsi hd
front intake fan
rear exhaust fan
vid = elsa 920 ge-force 3
cd rom = plextor ultraplex 40 max scsi
cdrw = plextor plexwriter 12/4/32 scsi
running win 2000 pro
power supply = Antec 400w
case = mid tower brand unknown
sandisk usb card reader
klipse 4.1 pro-media speakers
Keytronic (Lifetime Series) Keyboard
Logitech Trackman Marble FX
cabmeister
15
Thanks blargyblarg.
Just now went and got the latest drivers and installed them .
lets hope that works .
WOW what a prompt reply .
Thanks a bunch.:D
KB
5,406
389
Yeah this type of problem is usually driver or memory related. Update those drivers and if that doesn't work then try new memory modules.
cabmeister
15
Hi Guys
I am infact Running SR2 and also run Norton 2001 Anti Virus.
So Far i have had no problems at all, although its only been aprox. 24 hrs
since i installed the update drivers for the sound card .
Keeping Fingers/legs etc. crossed:).
Hope it works ,once again thanks for your express responces.:D
System Specs:
cpu= amd 1900+
nic= netgear
std floppy
front intake fan
rear exhaust fan
running win 2000 pro SR2
Logitech Trackman Cordless FX
TheWart
5,219
yes, i had similar problems in my home rig with the acoustic edge, but they went away about two versions ago for me.
