<DIV>I am trying to upgrade the BIOS on an ASUS P5A w\onboard sound. Im adoing this in an attempt to successfully install Wn-XP. I downloaded what I believe to be the correct BIOS file from ASUS - ab5i1010.zip. However, when I run the BIOS install utility I receive a message that the checksum is equal to 0000 andthe BIOS upgrade does not match the one currently installed. The current BIOS information is:
ASUS P5A ACPI BIOS 1007.A
Award Modular BIOS v. 4.51PG
Does anyone know which BIOS upgrade is correct and if it will fix the problem I'm having installing Win-XP.
Thanks.
</DIV>
Thanks.
