Hi everyone!
This is my first post....
I ran out of disk space (again).
I have a lot of pictures and I add about 500 GB a year.
Currently, I have internal SATA disk of 500 GB and external USB drive of 320 GB.
Both of them will be filed up in a month or so...
My idea is to buy an enclosure and another disk,
and when the new disk is full - put it back to the box and keep it this way.
Then I can get another disk and use the same enclosure until the next disk is full.
I have only one PC and I don't think I need RAID.
And I don't want USB connection.
Is it a good idea? Is there a better way.
Is there enclosure that has a simple way to replace disks?
What eSATA card and cable do you recomend?
What aluminum/fan enclosure would you recommend?
Thanks!
Thanks!
