Hi
i find that when i have an office doc [eg a word file open] and i want to either "save as" or "print", the first time i select either of these 2 options the document becomes unselected but the header flashes alternately in the "active doc" and "inactive" doc and likewise the taskbar for it flashes orange. i have to click on the orange-flashing taskbar entry to minise the document and then i see either the printing options or else the "save as" options which i can use normally. i then obviously have to click on the minimised taskbar title to bring the doc back up.
it doesnt matter which i select first: "save as" or "print" - this problem always happens; but from then on everything works fine and i can select anything at will and it works like it should.
can anyone suggest what setting may have been inadvertently set to cause this and how do i correct it.
many thanks
many thanks
