I ran Adaware....and It probably deleted something that it shouldn't have.
Upon restart, the boot process recognizes all the drives and counts the correct memory size, but once it gets to the windows 98 full size screen, it reverts to dos and lets you choose 1 of 6 boot options.
1. Normal
2. xxxxx (something I don't remeber)
3. safe mode
5. Command prompt only
6. Command prompt w/ ......
Choice 5 is highlighted by default. It says choose Command prompt only and run scanreg.
If I do this it hangs and does nothing.
If I try to boot normally, I get an error that c:\windows\system\vmm32.vxd is missing or corrupt
then it proceeds to shut down and power off.
If I boot in safe mode or go to the command prompt (but don't run scanreg) I get to a point where it says the C:\windows\himem.sys file is missing or corrupt. A line reading Device=C:\windows\himem.sys should be added to the config.sys file. If I try to go into edit config.sys, the mouse drivers are not active so I can't save it. I found where it says to look for to mouse.com files in the autoexc.bat and config.sys files, but I don't have either.
Lastly, if I boot from a win 98 disk & CD, I don't get an option of "repair windows" it looks like it wants to reinstall everything.
I've tried to copy the 2 files it says are corrupt from a disk, but when I restart, I get the same thing.
Is there a way to run a repair windows type program from the cd or floppy? or should I try to load the mouse drivers so that I can edit the config.sys file?
Thanks
1. Normal
3. safe mode
Thanks
