Please help: will putting a dvi adaptor on my vga lcd do anything?
alee25
828
also i have a geforec3 ti 200, can it run both vga and dvi outputs at the same time for dual monitor support?
thx in advance
EKAtBzboyz
323
geforce 3 cant do dual display
"dvi adaptor on my vga lcd "
do you mean switching from analog to dvi connectors on video card to lcd?
if lcd has dvi input then yes it will improve pic quality
if you are thinking of going
video card dvi connector => dvi/analog converter => analog input on lcd, no it will not do anything
alee25
828
ya i was referring to an analog monitor using a dvi adaptor to the geforece. So the only way i can get dual monitor support is by using 2 videocards?
Coherence
337
Using some kind of DVI dongle won't change the fact that you are using an analog LCD. In fact, if you look at a DVI connector, you'll see 3 rows of pins, and a box of 4 pins off to the side, with a kind of crosshair separating them. That box of 4 pins are the analog signal pins for connecting a DVI card to an analog monitor. In the end, you'll still be dealing with an analog signal on an analog monitor. You can't magically change an analog monitor into a digital one by adding some kind of DVI adapter to it.
alee25
828
can anyone recommend a good/relatively (under 30, preferabley under 20) cheap pci video card
Mday
18,647
you will get the most out of getting a new card. but if you realy want, just go to some search engine, like pricegrabber.com and look. they allow you to limit yourself to pci, and maximum price.
since this is a secondary card, you wont get 3d or anything, so you can get virtually any card. matrox and ati have the better 2d quality.
EKAtBzboyz
323
Pine Technology 32MB TNT M64 Video Card Model PVT03BB4 PCI Version Retail Box $35.00
ATI Xpert 98 8MB PCI VIDEO CARD - OEM $33.00
ATI XPERT 128 16MB PCI RETAIL $44.00
www.newegg.com for ^
just the ones i found there quickly
browse other sites, maybe local computer shops for "cleanout bin" deals
dszd0g
1,226
That is the case with DVI-I, but not with DVI-D. DVI-D only has the digital out. DVI-I has the analog crosshair and one can convert it to analog HD15.
