Can someone explain to me the proper fan size for cpu fan. I'm having some high temp reading for my celeron 1.1a. So I'm thinking of getting rid of the retail heatsink/fan and get a new one. I'm thinking of getting either the SK6 or the AX7. I'm not sure which fan size I need for these. I see different size for them such as 80mm, 60mm, etc... How do I know which one will fit or not? Also I'm using a cpu slocket , does this make a difference on what heatsink and fan size I can use?
Also if anyone that is using the sk6 or the Ax7. It will be very helpful if you can tell me what fan you are using it with and how loud is it.
Thanks in advance!
