Muse
This is my HDTV PC, a midtower system, it's running Windows XP:
GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard
Q8200 (2.33Ghz 45nm Core2Quad), copper core stock heatsink/fan
PNY 9600 GSO dual DVI PCI-e GPU
2x2GB GSkill blue DDR2-667 RAM
EVGA SuperNOVA 550 G2 550W 80 Plus Gold Modular Power Supply
MIT MyHD-130 HDTV PCI + daughterboard
Hercules Game Theater XP (GTXP) PCI sound card + breakout box
120GB IDE HDD for OS/Apps
Western Digital 2TB Red 5400 SATA III HDD for secondary storage
Midtower case
2x 120mm fans
I use it mostly for HDTV using its MyHD MDP-130 PCI card/daughterboard DVI output combo. I used to get occasional lockups but I don't think that was due to hardware failure. I think that had to do with software glitches possibly involving the PCI soundcard.
Now, suddenly, the last few days I have something else going on. The occasional lockups I used to get watching HDTV recordings (timeshifting), are different from what I'm getting now. The ones I used to get had everything freezing. My TV is setup to be on one screen and you can still compute normally on a different monitor. When I'd get those lockups, both screens would freeze. If I turned on the 2nd monitor I could see my desktop, mouse frozen. I'd have to reboot, find my place in the recording and resume. This would happen on average, I'd say, every 10 hours of HDTV watching time.
The last few days' problem is much more serious, and renders the machine completely unusable. The syndrome is this:
Watching HDTV, typically the problem starts with sound disappearing and generally no control over the HDTV app although the TV continues. A few seconds to several minutes later the picture freezes and when I turn on the monitor that shows Windows, instead of a locked up desktop, it's solid, either grey, blue grey or medium blue (not BSOD). But there's zero response and I have to reboot. Rebooting can go normally or the boot sequence can be crazy, -- instead of black and white characters on a dark screen, there are yellow/green horizontal lines all over the screen in addition to the white characters, and when this happens Windows fails to fully load and freezes. If I remove power from the PC for a few minutes it will do better. This morning after sitting all night (OFF!) without power removed, I turned on the machine and immediately saw the yellow lines were there at the beginning of the boot process and Windows wouldn't boot... the machine froze while trying to boot Windows.
I tried using my alternate Windows XP install, and it's the same there.
I have an alternate HDTV card/daughterboard combo and switching those hasn't changed things.
Is it likely the motherboard has gone bad? Could it be the PSU? Video card? I have other PSUs but not another video card that would work in this system. The memory has tested fine in the past. I don't know if it's feasible to test the memory the way the machine is behaving.
For another motherboard I would need PCI slot support for the HDTV card. The modem isn't important.
I'm thinking I probably need another MB. Is it possibly something else? Is there something I should try before buying another MB?
Midtower case
2x 120mm fans
