Using v3.2 of Memtest86. Let it run all night = 8 full passes. Zero errors reported.
Changed the test parameters under memory allocation to "BIOS-All". 47K errors reported thru just the first 3 tests.
Memtest recognized my configuration perfectly.
Actuall problem is system crashing during heavy processing. System simply shuts down and reboots. No blue screen, only a cryptic report XP report upon restart. Ruled out SW issues
Opened the box and felt around after crashes for heat. One of my memory modules is too hot to touch. Assuming the failure is heat related. Question is what is causing and why. What other tests can I run to diagnose source of problem. Someone mentioned Micro-Scope but not to sure.
Gigabyte 7VRXP v2
Socket A (462) w/Athlon XP 2000+
Southbridge : VIA 8233A(CE)
1GB (512 x 2 Mushkin DDR333) memory
nvidia G-force TI 4200
5 fan case
No OC'ing
Running Autodesk ADT/3D Viz 2005. No gaming
Thank you for any assistance!
Gigabyte 7VRXP v2
5 fan case
No OC'ing
