PLEASE HELP - Vista Explorer Problems
Smoolean
114
Hello everyone,
I was attempting to have Internet Explorer 7 run alongside my Internet Explorer 8 (as I code webpages and need to see how layouts look in both). I came across this IE7 Standalone installer and gave it a try.
http://tredosoft.com/IE7_standalone?page=1
Well, it didn't work, and it made IE8 not work either, so I uninstalled it. IE8 still didn't work.
Plus, in explorer (such as My Computer) whenever I click a folder, it brings up a new explorer window. It doesn't matter what folder options I select, it still does this.
Also, I can no longer view the Control Panel, but I can view the Control Panel Classic View, just not the Vista "Control Panel Home."
I realize it was foolish of me to install this IE7 Standalone, but I thought it would only install in it's own folder and not adjust any system files. Eeek, I wish I could go back in time...
I didn't have System Restore on, so that's not an option. I know, I'm an idiot...
I also don't have a Vista Boot disk, as this computer came with Vista installed on it to begin with.
Does anyone have any ideas of ways I can possibly repair explorer or IE files? Any tips, ideas, or any advice at all is greatly, greatly appreciated.
Thank you so very much,
Brad
MrChad
13,507
Try running System File Checker (sfc /scannow) to repair any damaged or replaced system files. Have you tried redownloading and reinstalling IE 8?
Smoolean
114
MrChad, thanks for the quick response! Your feedback is spot on. Last night, as my last attempt at fixing this issue before heading off to sleep I ran Windows Update and redownloaded / reinstalled IE8... and it fixed everything!
Also, regarding the Virtual Machines that MS offers- I've actually downloaded Virtual PC and the IE6 XP HD Image, and it works like a charm! My original plan was to go ahead and download the Virtual Image for IE7 XP3- but I have a slow connection and downloading the first HD Image took nearly all day. That's why I became desperate and tried to get away with a 20MB IE7 Standalone fix.
But slow connection or not- I'm going that route today. It's a guaranteed solution, and won't result in an unstable machine. Thanks again!
