Ok, here's the story.
A week ago I got myself a Sapphire X1900XT along with other parts to build a new gaming rig.
The rig is this:
A8N32-SLI Deluxe
Aforementioned GPU
Opteron 170
OCZ 2GB Platinum ed. DDR500
WD Raptor 74
Seasonic 500
I put it together and booted it up. No go. So after a few hours I isolated the problem--the GPU. My old Geforce 6800 GT worked fine in this new rig. I get signal to monitor and shows pre-BIOS stuff.
So I try the X1900XT in my older comp (MSI K8N Neo4 Platinum, AMD 3400+, TwinMOS ram) and it doesn't work in this either. The 6-pin connector from the PSU is connected to the GPU, I've had confirmation that this GPU works with the A8N32, the monitor I'm using has DVI input. Both cards have DVI output.
I ran out of ideas, so I decided this GPU was DOA. I was about to send it in for return.
But today I got an ATI 1900XT at a local store and tried this in my A8N32.
And guess what? IT DOESN'T WORK. I then put this in my old PC and didn't work there EITHER.
Can someone please solve this mystery? What am I doing wrong?
Did I really get 2 DOA GPUs in a row, or am I doing something really, really stupid?
Please help
The rig is this:
A8N32-SLI Deluxe
Aforementioned GPU
Opteron 170
WD Raptor 74
Seasonic 500
Please help
