Please help! trying to network with no success.
Dec 30, 2000
I'm currently using a D-Link DI-614+ as the router for my two machines(each running XP Pro) via ethernet.
I merely want to access the drives on each machine.
I've given each machine a unique name and matching workgroup.
When I open the netowrk connections on each, I see the respective NIC. I also see an icon for Internet Gateway.
When I select a drive and try to enable sharing i get the following:
An error occured while trying to share D. The server service is not started. The shared resource was not created at this time.
When I was using a Linux machine as a router, I never had this problem. This is my first store bought router, so maybe I'm missing a step somewhere.
Any suggestions?
JackMDS
29,546
422
For the propose of the initial setting, disable all software Firewall (including WinXP native
ICF); disable any active Virus scan or any other utility that might intercept Network Traffic.
If you are not concern about internal security WinXP has a fast simple method of sharing, no user permissions and no passwords.
Windows XP Simple File Sharing
WinXP Pro has an additional more secure method:
Windows XP Professional File Sharing.
XP File Sharing Trouble
