Two of my friends have bought identical systems.Only one has problems.
The following are the main components,
Athlon XP 2600+(333 Mhz FSB) with stock cooling/thermal pad
ASUS A7V8X-MX Motherboard
Transcend DDR333, 256 MB Ram
Samsung sp0411N , 40 gb hdd.
ATX Cabinet with Case fan and 300 Watt SMPS.
etc
The problems are following,
1. When the computer is powered on the HDD activity and power LED light up and fan /hdd sound is heard but after a second or so both LEDs stop glowing and the rotational sound also stops for 1-2 seconds, then again starts. This haapens once , everytime I power on the computer.
2.The voltage as indicated by the hardware monitor in the bios as well as ASUS probe shows 12 volt level fluctuating between 12.5 to 12.8(sometime even higher), and 5 volt at 4.75 volt. I tried replacing the SMPS but to no avail.The irony is that the identical twin of this system has 12 volt level at 12.2-3.
3. The temps as shown by the hardware monitor in bios as well as by ASUS probe are
Motherboard- 32 c
Processor- 50 c (idle) , 60-65 c load.
These temps are at the ambient temp of around 25 c. The twin brother of this system has
Motherboard temp- 30c
Processor temp-40- 45 c(idle) and 50-55 (load), at the same ambient temp.
I have checked, the system is not overclocked.FSB-166, RAM by SPD-166.
4. It takes ages to boot into either WIN 98 SE or WIN XP SP1(it takes longer in XP). I tried reformatting and fresh install and even when there is only the OS on the disk, it still takes too long to boot. I tried disabling all startup items but to no avail. The twin of this system has considerably lesser bboting time even with a plethora of software installed. I also checked and made sure that DMA is enabled.I also tried loading the drivers from the same CD as provided with the other system.
Now if you had the patience to read up till now, please have the goodness to answer my questions.
The questions are,
Can this problem be due to BIOS problem? Will reflashing the BIOS help? Both the motherboards have latest 1006 version BIOS( I checked on ASUS site).
Guys on the tech help forum advised changing the SMPS but did,t say anything about the bios. Do you agree?
etc
Motherboard- 32 c
The questions are,
