First let me apologize for any poor typing, as I'm doing this on my S4 and am not the best at texting. Anyhow!
A few weeks ago my computer started acting up, and at first it was the VGA led that was staying lit, with nothing displaying on the monitor. I went through the usual procedure of clearing the cmos and making sure all cables/ the ram were seated properly. Eventually I got it to work, and found out I had gotten a Trojan somehow (which I took care of) and figured that was what was causing the issue. A few days later the dimm led was staying lit and it again was not displaying anything, not even the bios. I took out the ram, sprayed it down with circuit board cleaner and replaced it; this lead to the computer again appearing to function properly.*
Now a few days ago it was doing it again, but this time it was the boot device led that was lighting up. So I pulled the cmos and left it overnight. In the morning I put the battery back in and started it up. This time instead of the TUF splash screen and the uefi bios, I got a black bios screen with white text, giving me the option to reset to default settings, which I did. The computer hasn't worked since.
I've tried the jumper, mashing f2 on startup, I took the the comp apart and reassembled it securely, I tried running it with only 1 dimm, without the ssd plugged in, the mem ok button, and I even bought a new cmos battery; nothing works. All the lights turn on, all the fans start up, and the mouse and my Nostromo light up; furthermore all of the motherboards diagnostic leds cycle, but the boot device led stays lit and nothing shows up on the monitor. I'm completely at a loss. I have a thumb drive in the USB port to try flashing the bios, but I cannot even do that.
So I guess my questions are: does anyone have any idea what is going on, how can I fix it, and if it is a lost cause what part do you think I need to replace? Before someone suggests it, no I do not have spare parts to switch them out.
Here is my build:
Asus Sabertooth 990fx
8 GB of G-Skill Rip jaws
AND FX-4170 cpu
MSN Twin Frozr III 7850
Corsair HX 750 psu
Crucial M4 ssd
Windows 7 home edition
Thank you ahead of time.
Here is my build:
AND FX-4170 cpu
Corsair HX 750 psu
Crucial M4 ssd
