Please Help! RAID 0 System Drives Not Booting (Drives have not failed)
Status
Not open for further replies.
CommissarMo
I'm very concerned that I'm going to lose data...
Problem: I have a slightly complex HDD system:
1. System Drives are 2 SSDs (OCZ Vertex) in RAID 0
2. Adaptec RAID Card runs 4x Intel SSDs in RAID 10
3. 2 HDDs run in RAID 1
History: I had to move the machine and unplugged all the HDDs for security. When I plugged everything back in, I got the "DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER" message.
I then noticed the CMOS was set in IDE mode, and it recognized all the drives in question. I changed it to RAID mode.
Upon restart, the Intel Matrix Storage Manager recognized my System OS RAID 0 array, and noted it as "Normal and Bootable"
But the drives still do not boot the OS. In the CMOS, now changed to RAID mode, the drives are not listed anymore, but are included in the 'boot order priority' list, even though they are not shown under the 'basic CMOS settings' list.
(At this point I unplugged all the other drives except the system drives)
I'm not sure why this should be happening at all, seeing as I just took the drives out, moved everything, and plugged them back in, originally in the same configuration. (I did move the graphics card into an x16 slot, since it had been in an x8 by mistake before)
I'm speculating that the drives are being recognized, and the RAID array is still in the Intel Storage Manager's memory, but the system is not seeing the drives as one bootable disk, and thus won't boot them.
I would like to know:
1. Is my data still accessible (say through data recovery specialists, or myself) - I imagine it should be, since this seems to be a config issue.
2. More obviously, How can I get the machine to boot the RAID 0 system drives.
Many thanks in advance if anyone can provide some advice.
Perhaps the boot loader is on 1 of the other arrays?.....if this is W7, you could use the repair install to fix the boot loader, however not sure what has happen to the Raid 10 array and the mirror....
Which array was built 1st and did it have the o/s before the stripped array had the o/s?, this would explain the boot issue!
From my experience, when you set drives to RAID mode, they no longer show up in the logical drive list, because it is handled seperately (not through the BIOS). Assuming your boot priority is set correctly, the only guess I have is the bootloader being on a drive that isn't plugged in (as noted above).
Edit: D'oh, didn't realize this message was so old and the OP has not replied to it.
make sure the cables are on good,I have a problem of my drives going offline untill I jiggle the cable then they reappear in windows 7
Status
