- Aug 24, 2001
- 256
- 0
- 0
Well, i think i've rebooted my computer about 12 times so far... and the day is still early
I've been having trouble with my comp's stability earlier... so i underclocked my cpu. It is supposed to run at 133/33 but my system would never be stable at that rate.
So, after a month of that... it was okay... never really had trouble with it. Until i decided to design a background in photoshop. Now, my system has been crashing like crazy. I can work on smaller images, like those that i do in web dev. But anything large causes my system to lock up.
My system would lock up while watching flash images, usually the larger ones freeze my comp. My comp also freezes whenever i try to play a game... I tried playing Battle Realms and i couldn't get the game loaded. I can however, browse web sites, use irc, use a text editor... but anything graphically intense seems to cause my comp to freeze, crash or lockup.
I believe it's a power supply problem, or it could be faulty ram. But i'm not sure. Since i'm on a limited budget, i can't just go and buy 256 DDR ram and a new powersupply. I can only afford one of the two.
Here's some specs... and i'm hoping that you guys could tell me if it does indeed look like a power supply problem.
MSI K7 Master motherboard
1333 Mhz AMD Thunderbird (remember, i have underclocked this to 1006 Mhz).
1 stick of 256 DDR PC 2100
2 Case fans
1 CPU fan
1 1.44mb Floppy drive
1 Acer 6x4x32 CDRW
1 Maxtor 9gb 5400 hdd
1 adaptech scsi controller
1 9.1 seagate 10k hdd
1 Sound Blaster Live value (pci)
1 Realtek 10/100 nic (pci)
1 GeForce 2 Ti (agp)
350w Enermax (365ew i think is the model num).
Some of the lockup errors i have received:
nv4_disp (infinite loop error, the driver got caught in an infinite loop)
kernel_stack_inpage_error (0xC000009D, or STATUS_DEVICE_NOT_CONNECTED, indicates defective or loose data or power cables, a problem with SCSI termination, or improper controller or hard disk configuration)
Now, here's why i think that it's a power supply issue:
Vcore = 1.96
2.5V = 2.48
3.3V = 3.27
5V = 4.53
12V = 12.72
The values above were taken from the bios during one of my many unexpected reboots.
now the 5v seems awfully low, and that would explain the kernel_stack_inpage_error i experenced.
The only reason i also thought this could be a ram issue, is cause, if ram is bad, everything screws up...
Please let me know what you guys think... as i can't afford to spend money on the wrong upgrade. And please let me know what you guys recommend as an upgrade.
Many thanks in advance for any and all help you may be able to offer
2 Case fans
1 CPU fan
1 Acer 6x4x32 CDRW
Vcore = 1.96
2.5V = 2.48
3.3V = 3.27
5V = 4.53
12V = 12.72
