Just upgraded my vid card to an AIW 7500, and everything went haywire. While installing drivers on initial boot - BSOD. Restarted, got the drivers loaded, started loading the software (tv tuner, etc.) - BSOD. Restarted, finished loading the software, restarted, now I get errors saying the registry is not present. Try to boot from floppy - doesn't help. Try to boot in safe mode, and it just hangs at the wallpaper and I get nothing. The way my system is setup, I also cannot get to the BIOS or CMOS and restarting my system takes approximately 5 minutes! Any and all help on both of these problems is appreciated. PLEASE HELP, ANANDTECHERS! I know someone knows the answer to this and I will be forever grateful.
Please see my system rig for system specs.
EDITGot tired of this crap, so I decided to reformat. Ran fdisk, rebooted, formatted, put in the Win ME cd and I get this error -
SUWIN
An error has occurred in your application. If you choose IGNORE, you should save your work in a new file. If you choose close, your application will terminate. I chose IGNORE, and got this error -
SUWIN caused a General Protection Fault in module 9XMIG.DLL at 0001:0014.
Now what do I do? I tried using my restore cd that came with the system and that doesn't work either (various other error messages when going that route).
SUWIN
