Please help...No sound...
CdnAtWork
61
I've been working on this for 5 hours now...tourettes is kicking in big time and i'm frustrated beyond belief.
I cannot get any sound from my system. the only hardware change is that i'm now using a Maxtor Atlas 15k drive as my primary drive. It's connected via an LSI 21320 Ultra320 SCSI PCI card.
I did a fresh install of WinXP, installed the latest drivers for my Asus a7v600 board, double checked that onboard sound is enable in BIOS but still no sound...
When i run the SoundMAX Digital Integrated Audio app, i get the following error:
"Audio is disabled or DirectSound is unavailable."
In my Control Panel/Sound and Audio Devices panel, it simply says "No Audio Device"
I uninstalled the drivers and rebooted and windows immediately says New Hardware Found. It picks up my audio hardware no problem. I've done this many times now (always removing drivers before installing any new ones). I've let windows decide which drivers to install, i've used the ones on my motherboard cd and i've used the updated ones from the ASUS site. they all install fine and tell me that my hardware is working fine and is ready for use, but i still have the same damn error messages about no audio devices, even after a reboot after installing the drivers.
What am i missing here? I've done clean installs on this system before, except it was on an IDE drive, and NEVER had this issue (or any other to be honest).
Can someone offer some ideas? have a similar problem? i simply cannot express how pissed off i am right now....
Thanks in advance folks.
Running WinXP Pro with SP1 and all available updates.
Here's my hardware setup.
ASUS A7V600 400FSB, SATA, Gbit LAN 6.1, Audio, 8xUSB, With Bios Rev 1006, VIA_Hyperion 4IN1_V451v
AMD Athlon XP 2500+ Barton Core 333MHz 512KB L2 Cache (overclocked to 3200+)
Vantec Aeroflow Heatsink with Arctic Silver 5 (keeps me around 40 idle and 44 full load while overclocked)
2x Infineon 512MB PC3200 400MHz DDR CAS 2.5 Memory
Sapphire Radeon 9800PRO Atlantis
Maxtor Atlas 15k-36GB on LSI 21320 Ultra320 SCSI PCI card
2x Western Digital SATA 160GB 8MB Cache 7200RPM
LG CD/RW 52x32x52
Vantec Stealth 420W PSU
DanTMWTMP
15,908
19
donno, a long shot..maybe a directx problem...
just try installing the latest directx.
Do you have any pci cards hooked in that we should know about? Sometimes (but usually a it conflicts w/ the video card), a TV tuner can really screw things up.
Try installing the drivers w/ antivirus software disabled (called ccApp.exe or something for nortons antivirus). My nvidia soundstorm never works when i install it w/ antivirus software running in the background. Also, you want to install software and drivers w/ the most stable settings possible. So put your barton back to stock and try that.
good rucks
CdnAtWork
61
Thanks for the suggestions Dan!!!
I've got DirectX9b. I removed the existing drivers and reinstalled with stock cpu settings and with antivirus, firewall and mbm completely shut down (closed all unnecessary processes in Task Manager)
Still no sound....
edit: forgot to mention, i have no other pci cards installed...
GregM425
38
My SPDIF out stopped working on my Shuttle AN35n Ultra when MS gave me a driver to download.
CdnAtWork
61
and the award for dumbass of the year goes to....
would you believe that when i was disabling the uneeded windows xp services, i actually disabled Windows Audio...
Just goes to show that even if you've done something many times before, talking to somone and not paying full attention to what you are doing can cause REALLY stupid mistakes..
going to go kick my ass now.
