Please Help! No post on P4 system.
luckyducky
I really need some help as to why this new system I just built isn't posting.
No beeps, only the CPU fan spins for a couple of seconds and stops.
I pretty much have taken every step I can to ensure any of the other components are not interferring.
First off, I have the motherboard entirely out of the case on the anti-static bag.
Second, only one stick of Ram is installed as well as just the single AGP vid card.
-I have made sure to reseat the CPU and HSF.
-Reseated AGP vid card and Memory.
-Connected CPU fan connector to both the CPU Fan and SYS fan connections on the M/B.
-Made sure ATX P/S (reg. and 12v) connectors are secure on the M/B.
Any idea as to what might be wrong? DOA MB or P/S?
System Specs:
Pentium P4 1.7ghz (Pre Northwood from Dell machine)
Gigabyte GA-8srx MB
Compucase 300w ATX p/s
RustyNale
2,220
If you have a meter, check your psu voltages. Make sure that the lead coming from the cpu/hsf is connected properly ( some mobo's are set up to shut down if the proper fan speed isn't detected)
luckyducky
<< If you have a meter, check your psu voltages. Make sure that the lead coming from the cpu/hsf is connected properly ( some mobo's are set up to shut down if the proper fan speed isn't detected) >>
I have a multimeter here, how do I go about checking the voltage from the PSU. Attach the meter leads onto the PSU atx connector?
I tried connecting the the CPU/HSF fan to both the CPU and SysFan connector on board. Both no go, fan comes on for 2 seconds and shuts off.
<< have you made sure that it isn't grounding out on a standoff? >>
I don't have the MB installed in the case right now. I have it on an anti-static bag.
Thanks for the responses so far. Keep them coming. :)
luckyducky
I can't swap out the P/S to test another since I don't have another ATX P4 P/S?
The CPU isn't cracked.
The CPU came from a Dell machine that had problems as well. The Dell Machine wouldnt POST, but it did give a memory beep.
However changing memory in the dell machine didn't solve any problems, so I just finally gave up on the dell and was hoping to use the same CPU in this new computer. But now Im having problems with this new computer. :(
I really need to figure out which component is giving me trouble in order to RMA it if necessary. Any ideas? Thanks.
jefflhunt
9
Well, just glancing over what you've posted so far, here are my 2 ideas for you.
#1, if your motherboard uses RDRAM (RAMBUS), they must be installed in like pairs. So, the problem could be that you only have 1 stick of RAM in if the board uses RDRAM.
#2, I know this one seems very elementary, but I once had the exact same problem as you when I built a computer. Spent 2 days messing with stuff and swapping out hardware confirming that it worked in other PCs. I would turn on the PC and it would have "power" for 1 second or so and then nothing. Come to find out, the problem was a very, very simple one. The voltage switch on the power supply came from the factory set on 230. Switched that puppy back to 115 and I was up and running.
Just some suggestions.
Jeff
luckyducky
Finally narrowed the problem down to the power supply. I plugged in the power supply in to my old machine(Cel 550) and it does the same thing with that machine. Not enough power to turn it on.
So now I have to return the power supply to Newegg.
Thanks for the replies everybody.
