I got a new MotherBoard (ECS K7S5A) and AMD Athlon XP 1800+ and am trying to install in a new case. First when I assembled in the case with a video card, but there is no display. The CPU Fan starts and the drives get power, but no Beep also.
Then I tried without the card, still no beep codes. I believe the MB is shorting out, I don't know how to find out. I am using all the required spaces or stand offs that came with the case and those that align with the holes in the MB. Then I removed MB from the case and I get the 3 beeps, may be no video. If I align the MB with the case, no beeps. If I leave it a little misaligned, i.e., the side with the connects a little away from the edge, it gives the beeps. I tried with different amounts of spaces, no luck. Now even with the MB away from the case, no beeps. Did I fry the MB? Please help.
The Power LED connecter for the case is a two-wire, but three hole connecter (middle one not used). But the MB uses a two pin for receiving it. How can I fix that.
That for help.
That for help.
