Originally posted by: Cheezeit
Hi,
I am building a computer for my friend, and he only has 500 or less to spend.
He dosen't really game, but i guess once in a while he will play somehting, so just in case i want to avoid integrated graphics.
He will mainly just surf the internet or do homework on it.
My idea is something based around an athlon xp
Im new to the lower end of computers, as i have only been looking at midrange, so im a newb to this. Please suggest some rigs/parts to me.
THanks for looking and any help will be greatly apprechiated.
You gotta be crazy to not go Dell:
DellSB - Dimension 4700 with 2.8Ghz Pentium 4 520 HT, 256MB DDR2 SDRAM, 40GB HD, 48x CD-Rom for $499 after Rebate with FREE 19" LCD Monitor! (Posted by: Apex)
Huge $599 worth of total savings on Dell`s Outrageous Deal Dimension 4700, bringing the price to $499 after rebate, with free shipping, with a FREE Dell e193FP 19" LCD ($429 value). You get the the new Intel 915G Express chipset based motherboard with 1 PCIe x16 slot (the replacement for AGP), 1 PCIe x1 slot, 2 PCI slots. It comes with a 2.8Ghz Pentium 4 520 HyperThreaded processor with 800mhz system bus, 256MB DDR2 SDRAM (in 1 stick, so upgrading is easy and cheap), 40GB 7200RPM S-ATA hard drive, 48x CD-Rom, 10/100 networking, Integrated 5.1 Channel Audio, and Windows XP Home.
Start here through the following link to Dell Small Business Outrageous Desktops: DELL DIMENSION 4700 COMPUTER DEAL
Now click on Customize It under Dimension 4700 $499
All of the options for the lowest possible cost should already be selected. Be sure to double check to make sure it has the free 19" LCD monitor checked (it should)
Upgrade whatever options you may want, though they may raise the cost. Here are a couple that you may want to consider:
512MB Dual Channel DDR2 SDRAM at 400MHz (2x256M) [add $40 or $1/month]
Discounted 2 Year On-site Economy Plan [add $59 or $1/month] or 50% OFF! 3 Yr On-site Business Standard Plan after $122 Mail-in Rebate [add $244 or $6/month]
80GB Serial ATA Hard Drive (7200RPM) [add $20] or 160GB Serial ATA Hard Drive (7200RPM) [add $60 or $1/month]
Scroll to the bottom and click on Continue
Scroll to the bottom and click on Add to cart
Finish checking out. Ground shipping for the computer is free. Send in your $100 rebate. This deal is set to expire 6/12/05.
Update: The high end Dimension 8400 is just $629 right now, thanks to a $549 total savings! It comes with a 3.0Ghz Pentium 4 630 HT processor, 512MB of DDR2 SDRAM, 40GB HD, 48X CD-ROM, 10/100/100 networking, 1 year warranty and FREE 17" LCD! Just follow the same link above.
$499 WITH 19" LCD monitor!!!!
