Please help my RIGHT ANGLE.
Bob151
I am over 20 years removed, I just forget how to solve for this equation. I'm trying to finish a closet redo, I need to cut some wood to the correct angles.
My triangle is a right angle triangle, a=11 b=16, so c=~19.4.
What I can't get are the 2 inside anlges. I forget this part.
It seems that according to google results, I sin(angle)=b/c. All the examples I have found, they solve for the b or the c and actually provide the angle.
I'm so removed from geometry (I liked it in school and did well, I just completely forget).
I don't know how to solve this when my variable needs to be sin'ed. Does it go accsin, cosin, help me with this puzzle please. I'm sure there are hundreds of you here that know.
Please post haste.
Thanks.
sin angle = opposite over hypotenuse
cos angle = adjacent over hypotenuse
To find the angle you will have to arcsin/arccos the measurements.
here, i'll do it for you.
A angle = 34.5
B angle = 55.6 degrees
For clarification, the angle will be opposite of the indicated side.
Originally posted by: QurazyQuisp
Soh Cah Toa
Sin: opposite over hypotenuse
Cos: adjacent over hypotenuse
Tan: opposite over adjacent
Aye,
Some Old Hippe Caught Another Hippie Tripping On Acid
The sine of an angle is equal to (the length of the side opposite the angle) divided by (the length of the hypotenuse).
The cosine of an angle is equal to (the length of the side adjacent to the angle that is not the hypotenuse) divided by (the length of the hypotenuse).
The tangent of an angle is equal to (the length of the side opposite the angle) divided by (the length of the side adjacent to the angle).
Whichever one you need to use, plug in the side lengths and then use the inverse function (arcsin or sin^-1 for sine, etc.) to find the angle.
A angle = 34.5
Thanks deadlyapp and everyone else. I knew they answer could be found here.
But for my future use, where is the arcsine on the windows calc. I see sin, cos, tan.... I'm sure that if they went through the trouble to add that, they would be complete on the arc functions too, right?
A angle = 34.5
Inverse sin, cos and tan.
A angle = 34.5
There's a checkbox labeled Inv. Click that and the functions should become inverses... I think.
Ah, yes.
Thanks, now I see how to get the answer for myself now with MS' calc.
Got the project done.
Thanks, to all who helped.
