Before i moved house, my computer was woking fine. but after......
Let's cut the crap, here is the spec/problem:
Duron 600 ( 6 x 100 )
K7T Pro Version 1
PQI PC133 128 Mb
Savage 4 Pro 32Mb
Seagate 20 Gb 7200 Rpm 2mb
Sony 52x CD Rom
NEC ( I think it is NEC i am not sure ) 8, 4, 24 CD-R
SoundBlaster Live Value!
Bufallo Lan Card
a CPU fan that i brought it for $70 ( which is very crap, i think )
and a Power Supply that came with my computer case for $230
I brought my PC about 1.5 years ago.
1. My computer would not start up ( the screen is black ), i check the code on the built in debug card ( 00000, all red ) , which means either dischange battery or damage CPU.
2. I brought a Duron 1.2 Ghz ( the sales told me that my motherboard does not support TB with 200/266 FSB ) and fit it in, my computer boot up and works fine. Since i want to plug in my lan card and a old hard disk, so i turn off my computer.
3. I plug in both, but the computer will not start up AGAIN!! just like before, I plug in another debug card to check, it shows "FF". Although i have lost my instruction booklet, i check over the internet for other simliar card's instruction, and FF means "Boot attempt (INT 19h)".
4. I don't understand what it means, and the onboard debug card shows once again all red. I try unplug the hard disk and Lan card. And the computer Boot up again!!! But in the middle of booting up Window Me, it stoped again. The debug card shows FF, and the onboard one i think is untrustable.
So what is the problem?? Could it be because of my crappy power supply??
K7T Pro Version 1
PQI PC133 128 Mb
Savage 4 Pro 32Mb
Sony 52x CD Rom
Bufallo Lan Card
