- Feb 27, 2001
- 142
- 0
- 0
I was upgrading to Win XP, and it started to install, and after the first boot, the computer froze right when the "please wait" thing with the windows logo appeared. I restarted, and next thing i know is that MY HARD DRIVE WONT BOOT!!!!! It says invalid disk or something. Thing is it wont boot. The BIOS can see it, and if I put it in my other machine (the one im writing this from) it can also see it. And It will even assign a drive letter to it. But if I click on it, I CANT SEE ANYTHING!!!! Like it was formated. BUT I KNOW MY DATA IS THERE!!!! Bc, if i select the drives properties, I can see that half of it is full, and the other half is free space, just like it was before it "went invisible"
I read on the net, and Im not completely sure, but is it one of these?:
-Lost Boot Sector
-Lost Partition Table
-Lost Allocation Table
Well I think its one of those, but im not sure. I also read that doing an fdisk /mbr could fix the prob, bc it rewrites the master boot record, but i dont want to do anything untill Im completely sure, bc the data in there is priceless. The drive is small (5 gigs), but half of it has very important data taht If I loose it, I loose my job.
PLEASE HELP!!!!!!!!!!!!!!!, I know you guys can help.
thanks
-Lost Boot Sector
thanks
