i dont even have a video card. i using the onboard video right now but stil no display. should i buy one to test it?
thanks and the cpu is brand new and i just want to focus and say that the motherboard, psu and ram or my corsair vengance 8gb ram might be defective
thanks gandya. i mean bestbuy refund policy is good. i bought one from bestbuy to test my computer earlier last week but my computer didnt turn on. the best bet is to buy one again because i returned one already and if i get one and if the results are the same, then i am more than likely to say that the motherboard is defective, correct?
You said in the op that "I have no video card so i'm assuming i am using the onboard video card which is the intel graphic 2500", but does this processor not have the full 4000?
After doing a bit of digging, I came across a few others having similar issues and all said simply the VGA port did not work, but the other port did. Can/have you tried the DVI?
option 1 = i havent tried using my vga-dvi adaptor but i will try that.
option 2= I did try to clear rtc ram. i removed battery and reseted but still no display.
option 3= i will try to swap vga cables to test this. i didnt try this yet
I think you have been confused, mostly is is the opposite (only the VGA works).
the i7 comes with the inte lgraphic 4000 not my i5 3570k
Not confused, just what I came across so I guess it can go either way. Point being, perhaps both/all should be tested?
a quick question. I think i should just try all the test and just rma the motherboard, but i dont remember if includes the motherboard speaker. Do you guys know if that comes with the case or with the motherboard?
First you check key board num lock led working or not ofter check any burning are there its fine
to remove processor clean with Ip
socket clean with tooth brush
Update: I rma'd it back to newegg and they said there are several severely bent pings in the cpu socket ! Is that why my computer had no display
