- Mar 16, 2000
- 54
- 0
- 0
Hey,
I just put together my new system but I can't seem to install any drivers for my MSI Geforce 4 Ti 4400. Whenever I install the detonator 28.32 drivers, after I reboot, nothing has changed. Under display properties/settings/advance/adapter, there is no device list listed, and the fields chip type, DAC type, etc all say unavailable. Under device manager, there is listed under other devices: "Video Controller (VGA compatible)". When I try to update the driver for this device manually, it doesn't detect it as a MSI GF4 Ti 4400 card, but as a standard VGA card. Can any of you offer any suggestions?
MY specs are:
AMD Athlon XP 1900+
Epox 8KHA+
Samsung 512 PC2100 RAM
MSI Geforce 4 Ti 4400 128MB
Thanks a lot!!
MY specs are:
AMD Athlon XP 1900+
Epox 8KHA+
Thanks a lot!!
