Please help me!!!!!!!!!
mariela6232167
Please Help me, i buy a board k7vta3 version:6.0a when i try turn off my pc this reset for turn off i need push the power botton in the cpu for 1 minute and this is the only way that my pc is turn off.
What can i do?
Thx, Very much!!!!!!!!!!!!!!!!!!!!
mechBgon
Oct 31, 1999
30,699
Go into the motherboard's BIOS menus to the Power Management menu. Is the ACPI FUNCTION set to "enabled?" If it isn't, you will probably need to back up all your data and files, then set it to "enabled" and reinstall Windows to solve your problem :( Hope that helps.
