I just got done hooking up my friends A7N8X Deluxe mobo and for some strange reason, it won't power up. The LED that's onboard that indicates that the board is recieving power is lit up, but nothing happens when I push the power button. The fans don't spin or anything. I've tried the following things:
- Checked to make sure the connector for the Pwr. Switch was hooked up correctly
- Checked to make sure the Pwr. Switch was still working
- Tried a different power supply
- Tried clearing the CMOS
Any other ideas? Thanks in advance.
EDIT: Disconnecting power supply, and leaving the clear CMOS jumper off for about 10 minutes did the trick... Should have tried that earlier. Thanks anyways for views and such.
