Whenever my computer resets (with the reset button, or ctrl-alt-del, or win98 reset), it never posts again, and I end up having to power off the system, then power it on again to get it to start up (post) at all. The Diagnostic-Led's (all 4) are all red when it just sits there after resetting. My motherboard is a msi bxmaster.
I'm not having any other problems with the motherboard (it's great), except for the resetting problem. I've checked to make sure it's properly installed. (is there something else installation-wise I shold be looking for?)
I don't think it's a problem with windows, because it happens even when I reset the computer before I start loading windows.
Here's my system, if it helps:
MSI BX-Master (latest bios, at defaults for power mgmnt)
Celeron566 (o/c'd to 898, but I've tried at 566, same prob)
128mb pc100 SDRAM
Antec 300W ATX Power Supply
Enlight 7237 Case
Elsa Gladiac Geforce2 GTS 32mb
CL SB Live! X-Gamer
Adaptec 2930C SCSI Controller
Hauppauge Wintv/PCI
Sohoware NIC 10/100
Maxtor 20gb 7200rpm (on primary built-in promise udma66)
IBM 10GB 7200rpm x2 (on primary ide)
Toshiba SD1202 DVD-ROM (on secondary ide)
All of the components have the latest drivers.
Any help would be greatly appreciated! Thanks.
BTW, this is probably a dumb question, but what is the email address or phone number for MSI's tech support? Thanks for reading.
128mb pc100 SDRAM
Enlight 7237 Case
CL SB Live! X-Gamer
Hauppauge Wintv/PCI
Sohoware NIC 10/100
