I need a little help please,
I have a Soyo KT400 Ultra Black motherboard,
I am running AthlonXP 1900+ processor
with PC3200 512MB Samsung memory,
GeForce4 Ti 4600 video card,
and a 60GB WD 7200rpm drive on Primary IDE
DVDRom 16x Toshiba on Primary IDE ( Slave )
LiteOn 32x CDRW on Secondary IDE
ZipDrive on Secondary IDE ( Slave )
Netgear NIC ( because the on board nic is not working well, very slow, Rhino II nic )
TurtleBeach Santa Cruize sound card
and a WinTV FM TV Card
Since I have heard that alot of people use the RAID 0 to help them capture video, since it is supposed to aquire the data alot faster then regular IDE. So i have decided to set up the RAID that is built in on the motherboard ( it is a HighPoint RAID chip that is on the board ), i have set up two Hard Drives, one is the IBM 40GB 7200 ATA100 & the other is a WD 40GB 7200 ATA100, i connected them, then i installed the software that came with the board & it allowed me to configure the RAID 0. Everything is working, the drives show up under windows as one drive ( about 76GB ) but the problem I am having is that when I capture video into those drives & then play it back it looks as if the drives would freeze up for a sec or two every 30 seconds or so, the video would freeze up during playback. I decided then to capture onto my reg IDE drive & I had no problems at all.
What could be the problem?
Please help.
Thank you
Please help.
Thank you
