ok, this is my first time building a computer so forgive me if i sound a little slow.
i have two ibm 20gs, one was a fresh drive and the other had stuff on it.
i installed winXP on the fresh drive, and hooked it up to the raid controller - a Promise Fastrak 100tx2 in the IDE1 slot.
it runs fine.
when i change the array in the raid's bios to use both drives in a RAID 0 array, it doesnt work. How do i incorporate this second drive?
i tried mirroring the two, and transfered the winxp install and everything over to the 2nd, then switch back to raid0 but that doesnt work.
im probably missing something blatantly obvious, but if you could just point me in the right direction it would be great!
it runs fine.
