Hey guys,
I just bought components for a new sytem through NewEgg. This thing so far has been nothing short of a nightmare for me. I am in dire need of help. Here are the specs and everything that is happening:
-AMD Athlon 64 3700+ San Diego 1GHz FSB Socket 939 Processor
-DFI LANPARTY nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard
-eVGA 256-P2-N376-AX Geforce 6800GT 256MB GDDR3 PCI Express x16 Video Card
-Sound Blaster Audigy 2 ZS
-OCZ EL Platinum Revision 2 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200)
-Seagate Barracuda 7200.8 ST3250823AS 250GB 7200 RPM Serial ATA150 Hard Drive
-NEC Black IDE DVD Burner Model ND-3540A
-Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply
I figured I was getting high quality parts, and would have little trouble, but it has been the exact opposite. Well, to start things off once I got the system built and powered on, what is the first thing I hear? The hard drive clicking and clacking like its typing out morse code. System can't detect it of course, so I rip it out and RMA it back to newegg. I need a hard drive so I run to Best Buy and pick up a Serial ATA 200g Maxtor....its all they had. Got home, installed it and detected it fine.
So I go to install XP....I format the drive and the system reboots to launch the GUI installer.....BSOD. It never gets into Windows at all. Reboot, BSOD. Reboot, BSOD. Wonderful. The BSOD I was getting was IRQL_NOT_EQUAL or something along those lines, I am at work and don't have the code with me. So I figure I set the RAM up wrong? The sticker says the timings are 2 2 2 5. The system auto detected it at different settings so I changed it to 2 2 2 5. Reboot, got into the installer. Begin to install windows finally.....BSOD. 🙁 :disgust:
I reboot and try again, and this time Windows installs. I begin to install all my drivers and update everything. I install the new 77.72 nVidia drivers, reboot....and I can't change my resolution out of 640x480 and 16 colors. Nice. I uninstall and reinstall and it works.
So I start putting games on, and begin to test out the system. I play for about 30 minutes...BSOD. IRQL_NOT_EQUAL. I check the memory dump in windows debugger and it says 'memory_corruption' as the possible problem. Reboot, test games again....they all end the same way running fine then a BSOD and reboot out of nowhere. Now when I reboot, my motherboard can't detect my SATA hard drive....wonderful, reboot same thing. :disgust: I had to unplug the power cord for about 5 minutes to get it to boot up again.
So now I have no idea what to do. I thought I was getting some high quality parts, and was hoping to have no problems. But this is a nightmare. I am on the verge of just RMAing the entire thing back to newegg and get a new mobo, ram, and video card.
I have a few more tests I can run, I am going to run memtest when I get home, and try the ultimatebootcd to run some other tests.
Does anyone have any ideas what I can do? I find it hard to believe that I got multiple peices of bad hardware in the same order, what are the chances of that? 🙁
