Please help me with my 8rda+ problem!
chrisfrog
75
ok, i've posted this on a few boards, gotta figure this out....
ok, start out.....
got an 8rda+, 2400+, and 512mb corsair pc3200 xms for christmas. I could not get this sucker to boot at all. so i ended up rma'ing it back. they said it was fine and sent it back. i had to pay shipping both ways.
i get it back, still would not boot. i was using an enermax 350w psu. the whole time it was gone, i was using that psu on my old system (1.1 tbird). so i finally get it back from them. and i'm sitting at this for a few hours and nothing will happen. i snag an old psu (250w) out of another system and plug it into the motherboard and heatsink fan. it boots....
so i'm thinking wtf. so i go and buy an antec 350w and it boots up just fine. (even though my old psu worked fine on my old system). i had it running for about 1.5 weeks perfectly stable at 195 x 10.5 . i had a alpha 8045 on my old system but in the switch over i lost a few of the plastic pieces to bolt it down so i threw in my old ocz gladiator.
a few days ago, i decided to purchase a thermalright slk800. it arrived today and decided to install it. i had to pull the mobo out to get it in though. so i do that and get it back in and try to boot up...... NOTHING.
after screwing with it, it booted for about 5 seconds and shut off. i smelled a slight burning so i'm freaking out, but it turns out the chip is fine. no problems with that. so i take the hsf off, its making contact just fine and nothing seems to be wrong and i stick it back together.
so i'm trying different things and it finally boots, but shuts off after a few seconds, i pull the jumper off the power pins and it turns back and shuts off (no burning now). i grab my old 350w psu and my other 250. and those will not boot it. yet all those power supplys will turn on when the green and ground wires are shorted. this just blows my mind cause i have had sooo much trouble with this....
i've tried everything that i can think off.... clearing the cmos, removing the battery..... nothing works.
what pisses me off the most, i've built probably about 20-25 computers for people and have never had a problem, yet whenever i do stuff for myself, i have soo many problems.
any suggestings?
specs:
AMD Athlon XP 2400+ 2.0ghz @ 2.05 (195 x 10.5) w/ ocz gladiator
Epox 8rda+ nforce2 motherboard
512mb pc3200 corsair xms ram
BFG (old visiontek) Geforce 4 ti4200
Adaptec AHA-2940U2W SCSI Controller
Sound Blaster Audigy Platinum w/ live drive
Creative 6x DVD-rom
Lite-on 48x CD Burner (flashed the firmware to 48x from 40x)
Seagate Baracuda 9gig 7200rpm u2w SCSI ST39175LW
Seagate 18.2gig 7200rpm u2w SCSI 80pin ST118273LC
Western Digital 40gig 7200rpm ata100 (WD400BB)
Western Digital 120gig 7200 SE w/ 8mb Cache (WD1200JB)
____________________________________
and then:
i was sitting thinking what i could about my mobo, and i go to do the cmos jumper, and i notice heat coming from the mobo.
the only thing that is connected is the psu connector to the mobo and the hsf fan. so i'm feeling around and finally notice my southbridge is burning hot. i mean hot
the computer hasn't been on since last night but the psu has been plugged into it.
i could only keep my finger on there for a second before it started to hurt
ok, so i pulled the psu connector off of the mobo and the southbridge got pretty cold. so i plugged it back in and it got within 5 seconds and i jumpered the power pins and it turned on but as soon as i pulled the jumper off it shut off and won't turn back on again....
i found a digital thermometer at my house, it maxes out at like 108F, but i snapped a pic when it was at 107.2...
keep in mind, this is when the motherboard is off but there is power supply is on.
edit: not when psu is on, but when power is running through it
Pic of the thermometer on the southbridge
mechBgon
Oct 31, 1999
30,699
Ok, are you positive that you've got your SLK-800 on in the correct direction? Although its construction isn't like a typical AMD heatsink, it does share a couple of properties in common:
  • One end of it has a step cut into the fins to provide the necessary clearance over the solid end of the CPU socket (see Figure 7, 13 and 14 here for the general principle)
  • Its clip is asymmetrical, and if the sink and clip are on backwards, the clip's pressure point is not over the CPU core.
On my Thermalright SK-7, I also had the situation depicted in Figure 14 there. The heatsink was on in the correct direction but was too close to the solid-plastic end of the CPU socket. I powered up and it immediately powered down because the CPU core was not in contact with the heatsink and was overheating. I pushed the heatsink away from that end of the CPU socket and it was fine.
Good luck, hope this helps! :D
chrisfrog
75
hmm, thanx for the info, but i don't think that was my problem cause the AS left a nice imprint on the slk800 that is was contacting and the 2400+ will boot on my other motherboard
mechBgon
Oct 31, 1999
30,699
How's that again? What power pins and why did you have a jumper on them? If you mean the power-switch pins that you'd plug the case's power switch into, then AHA! you are seeing normal behavior. They're not supposed to be connected continously. The case's power button is a momentary-contact switch. If you capped the pins with the jumper, that does the same thing as if you hold the power button down when starting a computer... after 4 to 6 seconds, it takes the hint and turns off again.
The fact that it worked outside the case makes me think something got to touching things where they shouldn't be when you put it into the case. Maybe a stray screw or standoff on the motherboard tray...?
LastRide
946
Its also weird that you say the southbridge gets real hot or do you mean the Northbridge?.
chrisfrog
75
i've started this and other boards many times this way, same as the switch works, touch the pins together for a second and it turns on....
what i meant to say was that when i took it off after a second it turned off. haven't been able to get it to boot since....
at the time that i did this the board was sitting on a non conductive surface outside of the case.
@lastride: yeah its the southbridge... the one without the heatsink on the lower half of the board, if you click on the link you can see in the pic which one it is
mechBgon
Oct 31, 1999
30,699
The symptoms where the board insists on powering itself off is screaming "THERMAL EMERGENCY SHUTDOWN!" at me. Can you look again at your heatsink, confirm that the end with the screwdriver-tip receptacle in the clip is at the top end of the mobo that would face the power supply, and make sure that the heatsink is slid as far DOWN the clip as possible, away from the end that has the screwdriver-tip receptacle, so it can't hang up on the CPU socket bar?
mechBgon
Oct 31, 1999
30,699
The board has had some issues where it gets boggled by low-rpm or variable-rpm fans, but I don't recall anyone having it shut down on them as a result (unplug them from the mobo's headers if you think this could be contributing to the problem). There are only two things I can think of that will make it shut down that way: a continuous connection on the power-switch pins (button held down or stuck internally) or thermal emergency signal from the CPU's core diode. Since you said there was a slight burning smell I thought of the latter. But you say the CPU still works?
If the board were to start and then just stall, then the onboard LED readout might have some clues to give, but it sounds like that's not the case? Anyway, sorry to hear about the aggravations :( I'm getting an 8RDA+ for my office system this week, we'll see how it goes. :)
chrisfrog
75
blah, i forgot to mention in the original post that i only had the mobo and heatsink fan plugged into the power supply
i think i'm just gonna buy another motherboard, got enough room on my credit card :) and sell whatever i end up with on ebay
Viper96720
4,390
Yeah some people are having problems with the 8rda+ while others aren't. You would expect it to work plugging in a video card, memory, and hard drive, cpuand power supply. If those components worked in another system. I say sell it or rma it
