Please Help Me with Mandrake Installations{Black screen while loading X Window}
Adeolu002
Please can Anyone Help:
I am trying to install Mandrake 8.2 on my computer. Everything goes alright until X windows tries to load. Then My screen just went black and shuts off signal to the Monitor
My Video card is ATI radeon 7500 64MB SDR
How comfortable are you with editing config files?
If you are open up /etc/X11//XF86Config and scroll down to the section labeled "Device".
Look for the entry Driver and next to it should be an entry in quotes. Remove that entry and type "radeon" exactly.
Check the video ram section and make sure it reflects the 64M of ram you've got.
Save the file, startx.
I edited the XF86Config file and have the same problem
Still need Help Please
This thing is driving me Crazy. But I am learning new stuff.
_____________________________________________________
There is some sort of Good in Every Bad situation.
Try running xfree86config or a similar program.
PS if you are stuck in text mode and need help Lynx is a good text browser for the internet. I use it quite often.
Check your video resolution. It may be set to 1600x1200 and your monitor can't handle it. Try 640x480 first and go from there.
