Please help me w/ PHOTOSHOP, please! Project due soon :(
IamDepp
52
I need to know how to incorporate this .ATN file to my photoshop work right now... the file I have is ad.jpg and I need to add this design to it in a new layer I think...
The file is "edge collection.atn" I don't know how to incorportate this ATN file... when I load it up from the file itself in explorer or something, I don't see Adobe displaying anything.
Please help me figure out how to use this ATN file, thanks
Magicthyse
1,095
Have no idea what an ATN file is. It's not a Photoshop class file to my knowledge.
You may want to double-check the source of the file, and whether it can be opened within Photoshop.
You may want to get a clue as well...
Juniper
2,025
I've made a search here for the .atn extension. It seems that it is a photoshop actions file. I think you have to put it in some special folder in photoshop's program file directory.
pulse8
20,860
If it's an action file, just load the action window and in the arrow on the upper part of that window, just click on it and then select load actions. Then find the file that you're trying to load and it'll put it in with the other actions. Then take it from there. :)
