Please help me understand how the 2GB per folder limitation works! (laugh later, teach now)
MichaelD
31,528
OK, I am having difficulty understanding the 2GB limitation on folder size that W2K has. Maybe it's b/c I've been up for 20 hours straight and worked my second 18-hour day in a row...either way, I need help.
I'll explain my confusion as best I can, OK?
Is the 2GB limitation:
2GB={FOLDER}--->with NO additional folders inside but just files totalling 2GB
OR
2GB={FOLDER}--->inside can be one or one hundred folders with contents totalling 2GB
I hope I phrased this question correctly. I really need to know as I'm trying to set up my MP3's on my FTP server. By the end of this weekend, I am planning on having around 50 or so CD's ripped to 256kb/s MP3's. :) The average CD, encoded to MP3 at 256kb/s is about 90-100mb. 2GB will come up quickly, you know? Thanks.
amnesiac
15,781
I've never heard of such a limit. I think it's only a max of 2GB of files in the root directory, not including subdirectories.
I've had folders with 4+ gigs for a while now.
ElFenix
102,407
8,595
i've got a folder with pr0n in it totaling ~9gigs.
ert....
ummm... mp3s, i swear!
silverpig
27,703
12
There is no such limit. I've had folders with 20 gigs in them before. No problem. I think you may be referring to the 2 gig file size limit (I think that's what it is anyways...)
MichaelD
31,528
Well, based on the comments of two AT friends that I respect very much, it's obvious that Iamadumbass. WTF am I thinking of then? Where did I pull this 2GB thing from?
So, if my G Drive is my FTP drive and G:/FTP is the root, then it doesn't really matter how much space I have....I.E. I could have 25 folders, 1GB each, inside G:/FTP?
DAWeinG
2,839
I think you might have meant the 2 gb NTFS that manufacturers preset it to and then the non uber n00b users have to format the whole thing and set it to their liking. I dunno I heard about this 2gb NTFS partition thing or whatnot also. Confused :confused:
Edit: BTW I heard that manufacturer thing on AT about a week back and how they were complaining that it was a stupid thing to do :confused:
MichaelD
31,528
Gee, I'm sorry I wasted everyone's time...I guess I'm hallucinating (no, I don't do drugs...I get pee tested, thanks very much!)...so tired. Thanks for setting me straight.
All I need to do now is buy a 100GB or better HD to hold these damn things...
