At work some people use several excel spreadsheets that they open as several Excel instances so they can see all the windows at once at different parts of the screen.
The system in question has 1.5 GB of ram and some of the Excels use upwards of 200 MB but total in task manger is below 1 GB, but Task manages shows only ~100 MB free ram.
CPU usage stays quite low to my surprise, but the PC is very slow. I think it is Paging a lot.
I have been looking at different sites like This one about optimizing Excel.
As far as I know the macros are efficient per the article, but I don't know some the sheets. Is there any quick analysis tool for that?
Also, I did not know printer drivers can eat up memory so I need to try that.
Some things I don't need is the clipboard. I usually disable it when I get the chance. Is there a way to lock it to 1 item only or other similar settings.
Any other ways to optimize Excel speed and memory usage would be appreciated.
Thank you
Thank you
