Specs:
Case/Power: Inwin s506 w/ 300w Sparkle power supply.
Case Pic
My power supply (I think)
Processor: 1.2 GHz Athlon on Epox 8k7a mobo
HSF: SVC Goldengate copper Heatsink with a powercooler 27 cfm 40 dbA fan (i think) www.svcompucycle.com
I have one sunon 80mm case fan in the front bottom of the case. I believe it is 39 cfm 32 dbA.
Case Fan pic
My PC seems very loud. I have tolerated it for a while but I want to be able to leave it on at night sometimes. Im not positive how much noise my powersupply is putting out (any help is appreciated) but i know that my HSF is probably the biggest culprit.
How can I quiet my case down so that it is quiet enough to leave on at night in my dorm room?
I was thinking of buying 2 of these for ~ $18:
Silencer 80mm Fans
Would this make a significant difference? I'm not positive but im assuming I'd have to get some sort of an adapter to fit an 80mm fan on my heatsink. Where can I buy one of these at a reasonable price? I really dont want to spend more than $30 or so total if I can help it.
If I do replace my heatsink fan and case fan with these "silent ones" would my PS fan make a significant amount of noise still?
Please help...any input is appreciated! Thanks.
-QwErTyBk
Case Pic
Case Fan pic
Silencer 80mm Fans
-QwErTyBk
