nucl3arboNg
I'm going to buy a P4 in like 2 weeks and need some questions answered. Please let me know what you think would be best for a pure fps gaming system that I'd like to bench with also. It will either be water/air cooled and would like the ability to run 24/7 at overclocked speeds. I'm asking these questions not taking money into consideration and would like a cpu that I can get high fsb with so only the items I list are being considered. Thanks in advance for your help .
1) P4C 2.4, 2.6, 2.8? I'm looking for the best combination between max oc and high fsb. At least 260-270fsb and 3.5ghz if possible.
2) Abit IC7, IC7-G, IS7, IS7-G, or DFI PRO875? I'm thinking that the non G version would be better since I don't really need gigabit lan or the extra sata ports. I only plan on using 2 36gb raptors in raid0 and use 1 ide drive for backup. So if the non versions will give me the same performance or better i'll get that.
3) OCZ 3500 DC PLATINUM, OCZ 3700 DC GOLD, TWINMOS 3200 CH-5, TWINMOS 3700? Once again high fsb is a must and would like some nice timings. Does it really make a difference with the timings at say 260fsb? The best overall ram here would do.
4) 2x256, or 2x512? Whichever will give me the best performance.
5) Which brand of 9800 pro is overclocking the best on average?
