ibex333
So I just got a Dell 144Hz 27" screen, and now I also want a 4k screen so I can have the best of both worlds.
I cant afford anything higher than around $450 so for this much, I am looking at a few models:
LG - 27UD69P-W (currently on sale for $400)
http://www.ebay.com/itm/LG-27UD69P-...&siteId=0&AdChoicePreference=false&rmvSB=true
Newegg has a similar LG 27UD58P-B for $350
https://www.newegg.com/Product/Product.aspx?Item=N82E16824025512
So I don't see why I should spend $400 for the first one. Is it any better? I don't see what's better about it.
I like 4k, 27" and IPS, I don't like 60Hz, and FreeSync since I dont use AMD. However, I cannot afford G-Sync on 4k or more than 60Hz, so it's moot point.
Do you know of a 4k monitor which is better than the ones I linked here in my price range? I appreciate comments/suggestions.
Thanks!
Thanks!
