Please help me overclock an av8 thanx
openation
1. I have an abit av8 939pin running an AMD Athlon 64 processor 3000+
2) I have OCZ 3200/400 modules (512 x 2)
3) I have Envidia Geforce4 MX4000 64mb
4) Ultra Power Supply 500watts
________________________________________________________________________
My system is like this:
current fsb frequency: 200mhz
current dram frequency: 200mhz
upstream LDT Bus Width: 16bit
downstream LDT bus Width: 16bit
LDT Bus Frequency: fsb x 5
Frequency: 1836Mhz
External Clock: 204/74/37Mhz
Multiplier factor: x 9.0
Agp Ratio (cpu:Agp ci) 74Mhz
DRAM Timings:
DRAM Clock: DDR400
DRAM Command Rate: 1T
Cas Latency Time: 2.5 clocks
Ras# to Cas# Delay: 3 clocks
Min. Ras# Active Time: 7 clocks
Ras# precharge Time: 3 clocks
Row Cycle Time: 12 clocks
Row Refresh cycle Time: 15 clocks
Ras# to Cas# Delay: 2 clocks
write recovery Time: 3 clocks
write to read Time: 2 clocks
read to write delay: 4 clocks
I hope with this information you will help me over clock it better.
Thank you
superkdogg
640
Read the posts on the "Quick and dirty" overclocking guides. They give you most all of the information. I have the same setup, so if you want help fine-tuning you can send me a private message.
