Fardringle
I know that similar questions have been asked in the past, but there are so many different opinions depending on the particular situation (and personal preference) that I would appreciate some specific answers based on what I need.
I have a POS case (don't even know the name) but it does have two front 80MM intake fan mounts two rear 80MM exhaust fan mounts, and it also had an 80MM side fan mount that I modified (Dremel rocks 😀) to fit a 120MM fan.
I currently have two cheap 80MM fans blowing in from the front, a 120MM exhaust fan mounted in my TTGI PSU and one 80MM fan blowing out beneath it (I don't have another one at this time to fill the fourth spot), and a somewhat loud, but effective, Everest (maybe Evercool) 120MM fan blowing in directly over the CPU/HSF.
I'm running an Athlon XP (Barton) 2600+ at 3200+ speeds with a Thermalright SLK-800 all copper HSF. I have the fan from this Masscool HSF sitting on the heat sink currently. The fan is rated at 37.87 CFM at 2700 RPM, but mine runs at 2450-2525 RPM for some reason so I'd guess I'm getting around 30 CFM out of it.
With the strong airflow that the front, side, and rear case fans provide, the ambient temperature in my case stays between 25 and 32 degrees Celsius, depending on whether my wife lets me run the AC (She likes it around 30 Celsius/85 Fahrenheit in the house). However, even with the high flow 120MM fan blowing directly over the heat sink, I'm just not able to dissipate the heat from the SLK-800 and my CPU is consistently at about 30 degrees Celsius above the case ambient (so around 55-63 C). The heat sink is most definitely moving the heat away from the CPU (the copper fans are always very hot to the touch), but my fans aren't pulling that heat off of the heat sink itself. This isn't 'danger' territory for the CPU temperature, but I'd really like to get it cooler so I can try to push the overclock up to 2.3 or 2.4 GHz or more (the CPU seems to be able to support those speeds with no problem, it just gets too hot to do it for very long).
So, with that in mind, I'd like to know what I can do to improve cooling in my case. I know that Panaflo L1A's in the front and back 80MM fan mounts and a quiet 120 MM fan in the side would certainly cut down on the case noise (it's pretty loud now), and I might end up doing that if/when I have some spare cash lying around, but I honestly don't think it would do much to improve the actual airflow as the fans I have now blow a lot of air.
My primary question is, which 80MM fan would be the best (not necessarily the quietest) option to put on my Thermalright SLK-800 heat sink to bring down the temperature of my CPU? I'd like to have a blue LED fan since my case has some blue LEDs built into it that match nicely with the Masscool fan I have now, but it's not a requirement by any means. Money is definitely a concern, so I don't want to spend a lot, particularly if I can get something reasonable enough to let me replace the other fans at the same without spending a bundle (I'd say $25 is probably the limit to replace everything if I go that route).
Thanks in advance,
Fardringle
edit: fixed some typos
Thanks in advance,
Fardringle
