Originally posted by: btcomm1
Are you saying that some adapters can't connect using WPA even if they are using the windows software to connect? Is it a driver issues that causes WPA not to work?
WPA is a requirement for current Wi-Fi certification, and should be supported on all current gear. However this wasn't always the case, and older gear (esp. 802.11b) might not support it. However, from what you've said, lack of support for WPA is not a problem for you -- WPA is available in the options.
If WPA works at least once with each computer, then it works. When it stops working, something's changed. Possibly the signalling environment, possibly the state of the router. Linksys and other consumer routers are known for locking up, etc., under heavy load and over time -- you could be seeing a variation of that.
So perhaps your issues have nothing to do with the encryption, and have to do with something environmental or the state of the router over time. Changing the encryption and the connection state of various computers back and forth creates a variation of setup parameters, signalling environment, and router state that might be confusing the issues.
Why do you have two routers? Are they both on? Is there perhaps some confusion with connecting to one of those or even some other router with a default "linksys" SSID?
Are you broadcasting the SSID? Try doing so, and disabling any unnecessary options, power-saving modes, etc., progressing from success to success, not undoing previous successes to go forwards.
Power cycle the computers and routers if/when you suspect they may be in a bad state. But for initial setup with not much traffic, I can't see why the router would be getting in a bad state, so I'd suggest power cycling that after the initial setup as a last resort over time.
